Helidan
Boat came out of the water recently and the boatyard offered to winterize the engine. Had a call from the engineer to say oil found in the coolant tank along with slight play in the turbo. I've never been able to get the engine to rev above 3000 under load. So I'm guessing I need the turbo reconditioned. Any idea on cost? Also what else might result in oil in the cooling water AND rpm loss? Engine has done 750 hours according to tachometer. Hoping a strip down isn't required. Otherwise engine seems to run very well, instant start, very little if any smoke, doesn't stall, good temps, good oil pressure, pulls good up to 3000.
