richardabeattie
What is the advantage over the rubber ones?
hi, I don't know if there is any advantage. Acetal is a good deal harder than rubber, although there are various grades of rubber hardness. However, acetal is much easier to machine, if I were making my own I would use acetal.
Thanks - I'll stick to what I've got but make sure they turn easily. That's probably the most important factor.
The rubber ones generally turn their axle with them, so the bearing is steel-on-steel.
As for acetal being "brittle" this is not the case, acetal will only be brittle if it is poorly moulded or extruded, or if it is of substandard quality.
The steel shaft should be prevented from turning in its steel mounting.
An Acetal bush should be pressed into the hole through the roller to reduce the friction on the shaft, but thi costs more so no one does this.
Oh yes it is! I have machined many components in it and, believe me, you don't drop it! (I have to admit they were thin sections but not that thin.)
If you are having those sort of problems then you should consult your supplier. Although I'm now retired I have spent my entire working life in the plastics industry, supplying and processing engineering materials, such as acetal, to the car, aircraft, medical and business machine sectors. Acetal is widely used where the part is required to act as a spring or bearing of some sort. It should not be brittle. It is also widely used in cigarette lighter casings and zip fasteners, I don't think it would be used in these applications if it were.
Every description of Acetal I see uses the word 'tough', which is just about the opposite to 'brittle'. My experience of it, as rudder bushes, is that it takes plenty of hard knocks.
