LadyInBed
Having had the symptoms of pump starting as soon as I run the taps, on advice from the panel, I repressured the Acc tank to 2 Bars. This has done the trick for a time, but now the symptoms have returned.
Should the Acc tank hold its pressure (in theory) ad infinitum?
Is 2 Bars sufficient?
Where are the points that it can loose pressure?
The obvious one that comes to mind is the pump 'filler' valve, are there others?
