Delfini
I have just bought a Lewmar Electric winch conversion kit and looking at the electrical requirements - the kit is supplied with a panel mounted 80A thermal DC breaker but my 24v distribution panel has a number of DIN rail mounted 80A breakers and I would prefer to use this set up for protecting the winch motor - the breakers already fitted and protecting the inverter, the windlass, the water maker and the battery charger are from E-T-A and marked 410-K-2-02
That part number denotes a single pole high performance thermal-magnetic circuit breakers for AC 240/3 AC 415 V/3 AC 500 V or DC 110 V
Im not sure if I can still buy these breakers but if I can’t is there a critical part of the spec I should look for in an equivalent - Ive read elsewhere you can’t use AC breakers in a DC environment but this clearly isn’t true for E-T-A
