sogood
Some may be aware of the fact that I finally splashed my refurbed Wellcraft back at the beginning of July. Since then, I've taken her out several times, when work allowed, and did some fine tuning and tweaking as needed. Last week, after doing some minor fiddling, I went down the bay and did some fishing, catching a few mackerel. All good, but I was aware of the dropping tide and wanted to get back on my mooring while I still had water. My harbour drains dry at low tide!
So, I set off early and all was good. Entered the harbour, idling towards my mooring with boat hook in hand. Lined up perfectly, caught my mooring buoy first time, but momentum pushed me on too much so I released it and came around for a second try. ( I'm VERY new to all this sort of thing, but getting there)
I came around in a wide sweep, avoiding other boats, a known sand bar and numerous buoys. As I set myself up for my second run, the boat suddenly slowed and wouldn't move forwards. My first instinct was to kill the engine. I didn't know if my problem was mechanical or otherwise. I then felt the boat being gently pulled backwards and an inspection revealed that I had snagged a mooring rope. The pennant line was wrapped around the prop with the actual buoy wedged up under the anti cavitation plate. I couldn't push the buoy back under water to unravel the line, nor could I rotate the prop with the buoy stuck where it was, so I had to cut the pennant to free the buoy.
Then I passed a rope through the end of the mooring rope, forming a long loop and allowed my boat to continue to drift away from my mooring. When I had drifted as far as the looped rope would allow, I pulled myself back into the harbour, towards my mooring and allowed momentum to carry me on, near enough to catch my mooring with the boat hook. So at least I was back on my mooring again and had access to my punt to get back on dry land while I still had water.
Next morning I returned at low tide and walked (yes, walked!) out to my boat and removed/cut the rest of the old rope from my prop, having better access to it. No apparent damage, prop spun in neutral and engaged forward and reverse, locking up where appropriate. Next evening I returned with the intention of taking a trip and checking that all was good. But it wasn't. When I turned the key, all I got was a single click. Nothing else. Both batteries and terminals all good, connections at the starter all good, as far as I could see/feel. The starter motor is very inaccessible and memories of the job I had when removing it during the refurb were coming back to haunt me.
I tapped on the starter solenoid, just in case, still no joy and I swapped out the master solenoid on the engine to no avail. So it looks like I'll have to pull the starter again, therefore the Aaaaaarrrrggghhh in the title!
I'll first pull the plugs and check for a hydrolock though I can't really see that being the case. When I snagged the line, the boat slowed first before stopping, on very calm flat water, travelling at walking pace. No backwash. Is this just one of those crazy coincidences?
Anyway, my big gripe is with the mooring line that I snagged. The mooring wasn't used by anybody and consisted of a rope, about 18mm, trailing for at least 20 feet as far as I could see. Tide difference is 3.0 meters. No chain, so it floated below the surface, held up by the buoy. A swinging mooring on a buoy with a minimum 20 foot radius! In future I'll make sure to trim up a bit when coming into the harbour, but in the meantime I have to sort out my latest problem. I just think it's inconsiderate to leave a mooring like this unattended and in such a way as to act as a trap for unwary boaters.
Rant over and thoughts on my problem much appreciated. Apologies for the long post.
