Mike k
I was considering how it would be best to remove an engine the 'easiest' way in terms of minimal or no aligning with prop etc.
looking at my pic, this is a shot of the port side stern engine mounting, the starboard is the same but the front two are slightly different but have in common that the 2 lag bolts hold down all the rest.
My question is can the engine be taken out by simply removing the two lag bolts on each leg that secure the base bracket to the GRP . If so then when re installing its a matter of repositioning excactly over holes in the grp and replacing the lag bolts.
I read a lot about alignments and I can see all the alignments are done above the base backet holding it to the floor so looking to avoid that if possible. Would welcome any comments however harsh on this suggestion!!
