noswellplease
I have what seems to me excessive white smoke in my exhaust combined with what appears to be above average uncombustible diesel in the exhaust raw water. There was a problem last month first launching when water in the diesel caused me problems but I have since cleaned out tank, learned all about 1st and 2nd filters changed both and at least got engine running. The engine is a Beta 25 hp and just 2 y.o. so I would not expect problems to be age or wear related. Power seems to be more or less the same as last year. When the engine cut out last month I thought possibly I may have been driving it too hard as the weather on that occasion was closing in and a bit nasty and I was trying to make port asap. There was no alarm for overheating but I could not swear the alarm works correctly as the tacko on the control panel has stopped working. On that occasion I just had to use sail to get me home and then started the investigation of fuel filters and tank. I found a slightly damaged impellor which I replaced but did not notice any loss of fresh water in the header tank due to overheating or any impurity. Thats about all I can say, the engine runs ok now just seems to be a lot of white smoke around especially when throttled up a bit and a good trace of diesel in the exhaust.Perhaps I'm overacting but if any forumites had suggestions as to other areas I might look at I would be grateful.
"I used to be indecisive, now I'm not so sure!"
