Jacket
Can I have some advice on the following questions:
i) I'm looking to buy some new mooring lines for my boat. Unfortunately I've no idea how long my existing warps are. As I'm awful at estimating lengths etc, and always end up ordering far more of things than I need, can anyone recomend good lengths?
The boats 24 foot, and I normally sail in the Baltic, so really need two longer lines to go to the stern posts in the danish box moorings, and two shorter bow lines.
ii) What sort of paint's best for painting interior glass fibre?
iii) My boats a Westerly, and the foam backing on the headlining has broken down. I'm considering replacing the headlining on the hull sides with carpeting. What sort of carpets best? Is there special stuff for this sort of application, or is it just normal carpet, of the sort used on office floors? Can the carpet go directly onto the hull sides, or should a layer of foam insulation of some sort be used? Finally, what sort of glue's best for this application?
iv) My boat has a reasonable amount of teak on deck, in the form of hand rails, tiller etc. This is varnished. However, as Going out to my boat to work on it means jumping on a plane, I'm trying to cut maintenance down to a minimum. If I just strip off the varnish and leave the wood bare, will this be OK, or will the varnish have broken down the oils in the teak that preserve it, or something similar? Is it worth using any of these teak oils and the like you see advertised?
Thanks in advance for any advice.
