VicS
a the moment if you are in the south east.
Roughly due west and unmissable.
Mars I believe visible in the east.
They are very clear in Cambridgeshire - just went outside and had a look. Mars is also clearly visible, if you look at Jupiter and Venus, then turn round 180 degrees and look up a bit! It's the bright, reddish star.
Dont count your swallows until they are hatchedAh 'tis Spring
Download Google Skymap (free) on your Android smartphone for an excellent real time plantearium on your phone. Enable the GPS & point it at the bit of sky you are intersted in & it will name all the stars & objects visible. Magnificent App.
I was using it on Friday having spotted Venus and Saturn while driving home and was surprised that the two planets were momentarily shown at the wrong angle to each other until the GPS acquired my position and the display corrected. Would your location on the earth surface make that much difference?
Your phone won't orientate properly without the GPS locked in. But yes, location DOES make a difference, otherwise sextant navigation wouldn't work would it?![]()
Can anybody help with this. We are in Mauritius (20 degrees south) at the moment and every evening after sunset at about 7pm, to the west or SSW are two bright stars/planets almost in a vertical line, mcuh brighter thn anything else in the sky, the lower being the brightest. The lowest disappears below the horizon at about 8/8.30pm local time. Anyone any ideas please?
