A couple of little computer quieries
castaway
31 Dec 2001
Solent
uk.groups.yahoo.com
My wife just got loose on the PC and has screwed up my MS Outlook settings. Previously all my inbound mail used to cascade in date order from the top of the page down and although it was not very sophisticated, I was happy with it.
Now I have been trying to restore this but can find everything except this setting, can anyone help pls??
Also how do I make this clickable... www.yachtsite.co.uk/fairweather
Thanks Nick
if you click (or is it doubnleclick?) the column heading, the email will sort in that sequence. She's accidentally done this to another column.
Got the site in question and then click favourites. Under settings you can make it go directly there.
If you right click on of the column headings you'll get all sorts of other options so you can sort asceding /descending by date/time or message sender or subject matter.
Dave L.
to make "www.yachtsite.co.uk/fairweather" clickable
type (url) in front and (/url) after the address.
note, the brackets used above are the rounded type, but you must use the square type, upper case (shift) not required.
so it should look like this when reviewed
<A target="_blank" HREF=http://www.yachtsite.co.uk/fairweather>http://www.yachtsite.co.uk/fairweather</A>
Hope this helps
Old Salt Oz....../forums/images/icons/cool.gif
<P ID="edit"><FONT SIZE=-1>Edited by oldsaltoz on 08/11/2002 12:07 (server time).</FONT></P>
Thanks for the help, now lets see if it works:
Regds Nick
