NealB
Our lovely old Seamaster 34 has twin Thorneycroft/ BMC Commander diesels. Both engines are in very fine fettle, and were fitted with new Bowman heat exchangers about 5 years ago (which have '250' cast into the body).
I feel rather nervous at revealing the profound depths of my ignorance to such an august audience, but here goes:
1) opening the drain tap in an engine block will drain the anti-freeze from the 'closed' side of the system, but will leave a little in the rear part of the heat exchanger (as the engines are installed with a slope, downwards towards the stern, of around 10 degrees). Therefore, to drain a heat exchanger completely, I'll also need to remove the plug situated near the exhaust manifold. Is that correct, please?
2) due to the aforementioned slope, no coolant is visible when the car radiator-type cap is removed. I'm therefore a bit nervous of refilling the heat exchanger: could adding too much coolant cause any damage to anything?
Thank you for your thoughts.
