mccrorytr
My distributor went bad and I want to replace the existing merc dist with a Hi perf chev HEI distributor. Other than setting the mechanical advance curve, dealing with the vacuum advance setup and rewiring the shift cutout switch to work properly is the anything else I should consider? it used to plain out approx 3800RPM, what shpuld the total advance at full throttle be?
