arthurpavlovic
New Member
Hi folks.
Brought my Balaton 24 (cruiser) out last week but as I came off the mooring, against wind and tide, and opened her up. The engine died back and I had to reduce throttle to get her to run normally. She is in the club boatyard now. I will get a barrel and fill it up and try a few things. (No line for water muffs.) The only thing I have noticed, is that for years, when I squeeze the bulb, in the fuel line, it never gets hard. (I do not normally use the Honda above quarter throttle (the engine has a governor, until it is put into gear, so the problem may have been there for years.)
Would you please let me have your suggestions as to cause of my problem? (Engine dies back when throttling hard in gear.) I have tried carb. cleaner spray but with little response.
P.S. It is the 9.9hp which I suspect is the same engine as the 12hp and the 15hp. If I have to replace the carburetor, is it interchangeable with the 12hp and the 15hp? What I am trying to ask is can I put a carb from a 15hp onto my 9.9hp and turn it into a 15hp? Thanks.
All suggestions, comments and contributions, will be greatly appreciated.
Many thanks,
Arthur
R.I.B.C. Barrow in Furness.
Many thanks,
Arthur
