kevinrbeech
Wooden mast in excellent condition, sanded to wood 4 years ago and coated with 3 coats of thinned varnish, stored dry since.
The mast was stepped on the coach roof in a tabernacle (I think that's what it's called), which is also available if required, is 8 m tall. The first 1m is square the girth at this point is 40cm. It's all wrapped up so I can't see the label but I'm sure it was made in London. It is a sectional built one as opposed to one solid piece of wood. Still has wire through to top for mast light. Boom is about 100mm diameter and currently has roller reef fittings, all brass. Spreaders are OK condition but one fitting needs repair. All standing rigging is stainless and appears in good condition. If you need to know any more just ask. I have photos of boat/mast before lifting out, if you send your email address I'll send what I have.
Located in Dorset. Offers.
