dpb
First off this is not a how to post, infact it may turn out to be a how not to post as the work is under way.
The work is being carried out on my project boat, subject of this thread:
My 80's Sea Ray 197 Monaco Project
The reason for the conversion is as a result of problems with the engine restore related on this thread:
Mercruiser 4.3 V6 rebuild fail.....so next step?
To fix the engine issues was going to cost me in the region of £2000 and I still had a seized up leg to sort out and the boat is unlikely to be worth such further expediture.
At first I considered a change to an outboard of equivalent power to the existing inboard but the cost of a decent engine and appropiatley engineered mounting arrangement would be equally if not more unviable.
Eventually an idea came together based on:
A slow boat, call it a river or lake launch , would be a useable boat.
The existing bathing platform is solidly built and can take at least three adults moving around on it with out moving. (say at least 250kg)
An outboard of 15 to 25hp should achieve 10knots.
Such an outboard weighs 40 to 75kg
A decent 4 stroke 15 to 25hp can be got for about £1500
Breaking and selling the existing engine is likely to achieve at least that amount.
Simply bolting the outboard to an L bracket fixed to the top of the bathing platform was not going to work as it would be too high, even for a long shaft.
The top of the outboard mounting had to be a few inches below the top of the platform.
The basic design then is to build a 'box' that hangs from under the bathing platform so that the mounting point for the outboard is in line with the rear of the platform.
The section of the platform that is aft of the existing cut out will be removed to accomodate the motor head.
Construction to be from 18mm ply and GRP.
The ply is screwed together using resin as a glue.
Wedge pieces smooth the corners and a filler made from resin with added granules fills any gaps before laying up the fiberglass
The bottom half of the box was glassed up first before fitting the base of the outboard well. The box overall depth is determined by the need to have something to fix the lower outboard fixing bolts to which is why there is going to be a hatch for access.
The ply is all 18mm that was recycled from some shelving that I made years ago.
double thickness for the outboard to be mounted to.
It is probably standard ply which should not matter if my glassing is done properly. Plus the boat will be trailer stored.
All faces and edges of wood have been 'painted' with resin before assembly.
The timber pieces are pressure treated.
I have placed a couple of off cuts of ply in a bucket of water to see what happens. (nothing yet after 2 weeks)
Thats it so far.
My intention is to probably paint the box with waterproof paint for good measure, mainly as I have no idea how to apply gel coat, plus I am not sure how waterproof the lay up is without a gel coat.
The existing hole in the transome will be blanked off with resined and painted 12mm marine ply, the idea being to be able to convert back if required in the future.
Any comments welcome!
Thats it so far.
