6mm tubing push fit 3 way valve?
davethedog
13 Feb 2016
Afternoon,
Looking at fitting our watermaker at some point in the next few months and looking at fitting options. The fresh water output is sent via a 6mm nylon hose and I am after a way to fit a switch that then allows the fresh water to be switched between a spigot (for testing and initial running) and then switch to the fresh water tank.
I have searched on the net and can find lots of 6mm fittings and single in line valves but not what i am after, so any ideas? Something that has one input but a switchable 2 way output (hope that makes sense)?
DTD
This is the type of valve I used with pipe fittings screwed in to the ports to suit the pipes you wish to use
