6hp Mariner 2 stroke - cant get gear shifter yoke back in
Housecat
New Member
30 Aug 2021
Not sure if it's universal to call it a gear shifter yoke but the images show what I am referring to. The yoke won't fit back in, and therefore the little plastic clip (gear shift select lever) cannot clip onto it securely. What happened after I initially took the clip off that caused this misalignment ? I must be missing something. Any help is greatly appreciated.
Best, Austin
No images. Probably because you are a new member ( only 3 posts to your name) although you have posted a picture before of a Yamaha 6
Can you ID the engine more precisely with year and serial number. Also indicate where the part you describe as "a gear shifter yoke" is located. Part of the shift linkage presumably ?
If no one here can help post your question on the Mercury / Mariner board of the iBoats and/or Marine Engine forums but ID your engine fully.
Mercury & Mariner Outboards
Mercury Mariner Outboard Forum
