6" Rubber Flexible Exhaust Pipe Supplier
Jim@sea
12 Feb 2010
Glasson Dock
Having found the 6" Flexible Rubber Exhaust Pipe leaking at a joint I need to replace it and I need at least 4 meters. This is the stuff with the metal coil within it. Does anyone know where I can get some please.
Plenty of suppliers about, however these guys are prompt shippers and hold a very large stock and as wholesalers actually supply the likes of ASAP supplies.
http://www.hoseworld.com/acatalog/CORRUGATED_MARINE_DIESEL_EXHAUST_HOSE.html
Not cheap stuff, however have found that Hoseworld supply a good quality hose which is a tad more flexible than most brands.
Additional note: Measure your stainless steel connections CAREFULLY nominal 6 inch replacement hose can be 152mm or 153mm, remember this stuff has zero give. Measure and measure again to avoid expensive mistakes.
