6.4mm rivets
Martin_J
19 Apr 2006
Portsmouth, UK
As Coaster says.. the lazy tongs riveters are not so good when working up a mast.
I have (and use) the Faithfull long-arm riveter...
http://www.toolbank.com/p/FAIHDLAHR
It does not push you away from the work you're doing and even catches the mandrels.
BTW - It is available for about £30 from other places.. your avatar just doesn't say where you are..
NormanS
10 Nov 2008
+1
I fitted steps to my mast using this Faithfull set, with 6.4mm monel rivets. No bother, mind you, the mast was on trestles.
PeterR
12 Dec 2009
I borrowed a Rolson lazytong riveter to fit a spinnaker pole track with 6.4mm monel rivets. It broke after about 4 rivets. I then bought a Faithfull long arm riveter which completed the job with no problems and was a lot easier to use up a set of stepladders.
