40 hp Yamaha model 676 Spark Plugs
Pietre
New Member
5 Mar 2007
I would like to find out the correct spark plug electrode gap
for a 2stroke twin cylinder 40 hp Yamaha outboard motor model 676.
Would realy appreciate this info.
Peterpaul South Africa.
Don't know what Year a 676 is. /forums/images/graemlins/confused.gif
If you use NGK. B8HS 8- 10 for 2 cyl jobbies 92 onwards. Gap 25 thou.
B7HS-10 ,ok if You pootle along a lot.
B8HS Gap 10 thou.
B7HS again if You ain't "thrashing" it all the time.
B8HS or7 for older engines I reckon.
Same thread type and reach and electrode type.
The "10" ones run with a bigger "gap"
Most Japanese engines will "spec" NGK's as standard fit.
To use Champion or Bosch or whatever just use a cross reference chart to match.
Personally use NGK anyway.
What plugs are in it now?
K.
Your such a bright spark /forums/images/graemlins/laugh.gif
Seriously what a comprehensive answer
cheers Joe
Comprehensive School education.
Bright spark?
Tee Hee!
No such luck.
Parting Comment from the Headmaster, on the Old School Report.
"Richard must learn to realise, there are more things in life than Football!"
I kid You not.
Silly tw%t if they'd have coached Me properly, I,d haven been banging em in for
Llannerchymedd UTD.
Get gates of nearly a hundred sometimes, well nearly that when it's shearing time.
The best shearer in the Village is called Alan
Alan Shearing! Get it!
Cor I,m on form tonight.
Joe---- P%ss off /forums/images/graemlins/smirk.gif /forums/images/graemlins/laugh.gif
well, the hs-10's should be gapped at 1mm, that's what the 10 is for ... 1.0 mm
normal HS plugs are gapped at 0.7 as a rule.
lord knows what that is in thou, but 10 thou sounds tiny . /forums/images/graemlins/ooo.gif
Imperial Measurement.
For the Empire!
What Empire?
Dunno we,ve give it all away. /forums/images/graemlins/frown.gif
Rands, Kruggerands, Euro's What the F happened to L.S.D I mean Pounds Shillings and Pence not the Drug!
What the F is a friggin Zulu doing with an outboard anyway?
Don't want to BOAR You with any War Stories however.
Can't think Metric Measure, sorry but I,m an Old Fart.
Peterpaul (any way what happened to Mary?) gis an idea, what plugs where/are in it innit?
See You can see, I don't need L.S.D /forums/images/graemlins/grin.gif
Heads gone, without the need of hallucinacianery aids. /forums/images/graemlins/smirk.gif
Aids, now that's another Storey
They have no clue..........they flew away b4 it 'appened /forums/images/graemlins/laugh.gif
The gap only needs to be"ish"on a poxy outboard any way
ps that"look'look again" ad is doing my head in
cheers Joe
