skyflyer
I have an ancient 3hp 2-stroke and have just replaced the impeller and given it a start-up and run (without prop) and fairly low revs as its not under any load.
What sort of 'flow' should i expect from the cooling water outlet under these conditions? I am getting a feeble dribble.
Assuming this is a bit on the low side, and that the channels are caked up with years worth of salt, how long do i need to run it in fresh water (maybe with a prop to give load?) to allow salt to dissolve out - or is that a futile hope?
