bikedaft
Hi,
Engine running fine. Cooling water pumping through, impellor vanes all fine (opened it to look). Alternator charging batteries. Connections between engine and warning panel look fine (opened, checked, then reconnected).
Block, cylinder head, heat exchanger all seem to be heating up fine, and equally. At idle and under load.
Not had this before. Very little online.
Suspect next I open control panel and check connections?
Any other ideas?
TIA
Any other ideas?
TIA
