kcrane
I'm pretty sure this question comes up often, but a search didn't give me quite the clarity I was hoping for.
We normally plug into a 16amp supply, using one of the smaller blue plugs (three round prongs, one larger than the others two and a notch on the socket to make sure it goes in right.)
We have occassionally drawn more than 16amps (two small heaters, then add a toaster and kettle) and it sometimes trips off at our panel on the boat rather than the marina trip switch on the pontoon. Presumably this shows our onboard electrics are designed to draw no more than 16amps.
Having said that we have a 7kw generator, which at 220v presumably can supply around 30amps?
We're moving to another marina for the summer and they've warned us the berth has a 32amp supply.
We have an adapter, which has the larger blue plug with a short cable attached to a blue 16amp socket.
Will it be OK to plug this adapter into the pontoon 32amp supply, then plug our normal 16amp lead into the trailing socket?
I assume we'd need to at least keep an eye on what we are drawing as the pontoon supply will not trip, but with the safety fallback that our own panel should trip if we draw too much?
If the type of supply was different (3 phase?) would the plugs be different colours?
