rbcoomer
Hi All,
As a boating newbie, I'm hoping someone might be able to shed some light on a small running issue I have?
I brought first boat last year and had engine serviced locally before I used as boat had been stood a long while unused. They replaced impeller, oils, plugs and cleaned up the shaft which was very rusted. On my first outing the engine failed to restart and a friend towed me back in. Having recharged the battery, I diagnosed that there was no charge from the engine so ordered a replacement rectifier pack. The next trip out was on a local river and apart from a tendency to stall it restarted and ran ok. Third trip it stalled and wouldn't start - another tow in!
I didn't use again last year as I wanted to sort various issues as funds allowed before going out again.
Over the winter I have replaced the diaphragm in pump (was very deformed and small seepage in seal), cleaned all the wiring and re-terminated battery leads. I've just replaced battery with a biggish 100aH marine unit and also concluded that the kill cord switch was a bit sensitive.
I now have the engine running fairly well and although a little 'lumpy' it idles much better than before (it was stalling after 20-30 seconds). I've also (on suggestion of a friend) given a good dose of Carb cleaner, which seems to have helped too.
The engine now starts 'on the button' revs up ok and pumps water, but still has a tendency to stall when dropping off the revs (it splutters most at this point). I'd really like to fix this a.s.a.p as I have a Rally on Easter Saturday which is in coastal waters! As we are looking at the possibility of 8knt easterlies, I really don't want to get stuck broadside restarting engine in a 14' boat with a 3' swell any more than I have to!
Any suggestions/diagnosis/pointers gratefully received.
