jwaldin
#1 When under sail if I leave my engine in neutral the prop turns quite fast at times. We actually judge our speed that way. Is it harmful to the transmission in any way?
#2 I have recently changed the cooling system from fresh water cooling, using a heat exchanger and external belt driven pump, to salt water cooling using the internal engine pump because having the external Jabsco pump meant a third belt on the fly wheel, making hand starting impossible due the extra drag. (I'm getting to the question). I had to remove the small bronze plug on the starboard side of the engine and replace it with a temperature sending unit. This would have been where I could have inserted a scacrifical zinc plug. So I don't have a zinc in the engine. How important is it to have one now that sea water is in the motor and if I should have one any suggestions as to where I could install one?
#3 When I bought the book the morse control unit had been actually bent inside by someone trying the shift the transmission into forward. I removed the unit and straightened it but when I then tried to shift into forward the stubby little lever on the transmission is so hard to move, even by hand, that I cann't use the morse control unit. The shifter is about 8 inches long. Is there a problem with transmission or are all MD1 transmissions so hard to shift? If I add some lenght to the shifter to gain more mechanical advantage then the throw length of the morse cable isn't enough to move the shifter far enough to get the motor in and out of gear. It's a quandry what do to.
