cmedsailor
Lately the propeller of my 2hp honda outboard turns at idle speed (seems to be always in gear). What could be the problem?
I don't know about your Honda, but all 2hp engines I've used are permanently in gear. Did yours used to stay still at idle?
I may be wrong, but there is probably just a bit of drag on the clutch and is no harm. I think mine does it if the tickover is too high.
This happens to me sometimes after I've stripped the carb. If I don't position the throttle cable clamp correctly the throttle doesn't close properly. Is the idle screw always coming into play when the throttle is closed?I have adjusted the tickover with no success. The drag is quite a lot, something have definately changed. I will try replacing the valvoline in the gear box (if I manage to undo the screw) and see what happens. To be honest I never did in the past (though I change the oil every year).
If its one or both of the shoes sticking then it should be quite obvious if you try to turn the prop by hand that it is also trying to turn the engine.
they can't do much for £50. I bet they only blew out the carb and checked the plugMay be worth having it serviced - mine was a pig to start but after a £50 service its sweet as a nut!
