xeitosaphil
I'm trying to replace all the parts of my Japanese 2gm20 waterpump, and managed to remove everything except the shaft seal. Can anyone tell me if this seal has a metal outside case as it is stuck to the body of the pump with no movement between outside of the seal and pump case?
Have tried soaking and possible drifting from impeller side of pump , but only managed to destroy the rubber lipseal but with no successful movement of the outside case.
Any ideas on its removal please would be gratefully accepted.
Note:
Guide for others maybe doing same job, be very careful drifting bearings off the shaft using socket and hammer, I managed to bend the shaft midway flange, because the socket wasn't deep enough, and the bearings were very tight on the shaft. So now also need a new expensive shaft as well.
Any ideas welcomed
cheers Philip
Note:
Any ideas welcomed
cheers Philip
