290 sterndrive oil seals
224 still not in water..still pongy petrol..but now, can't get correct oil seals for prop shaft on 290 sterndrive. The official part number has been checked by 2 dealers incl VolSpec and there's only 2 types..the duo or single prop. Mine's single.
We even measured the new seals to check we hadn't got the duo prop's.
Oh sorry, I forgot to tell you the problem, I'm so pissed off.....
The problem is that the seals are too big for the shaft by quite a margin. The part number has been double checked. It's even the same for the 280s...so the diameter of the shaft can't have changed.
Help before I go out and buy a Macgregor 26x then all I've got to worry about is strings and rag....
hlb
RIP
Any Pub Lancashire or Wales
If you still have the old ones. Take them round to your local bearing/oil seal shop. Try Yellow pages under engineering or whatever. Bearings and oil seals are nearly all standard stuff and much much cheaper from a specialist shop.
No one can force me to come here-----------
----- I'm a Volunteer!!!
Haydn
BarryH
31 Oct 2001
Surrey
As haydn says go to the people in the know. I use Mercury bearings and Seals in Ewell surrey. Just give them all the numbers stamped on the old ones and they can match them. Oils seals from volvo £23 each, but only £4 from mercury. They have branches all over the place.
Wha'dya mean "I'm always playing with this engine" its the only way to get it to run!
