290 DP drive stuck at trim level 5
TerryA
Active Member
17 Mar 2019
The boat has stayed at the mooring since the pandemic. Checking everything I discovered the drive leg wouldn't move off level 5. The elecrtics seem fine, the relays are clicking but nothing is moving. Unfortunately the leg is hidden from view under a rear platform so I can't just stand on it to give it some encouragement. Are there any quick tricks that would release it or am I due to spend another small fortune on a lift-out adn service?
If relays are clicking but pump not running I suspect the problem can be solved inside the boat without the need for a lift. Either the relays are not passing current to the pump (they can click and still not pass current) or they are passing current and the pump motor is seized/dead. Quite simple to test which one it is with a multimeter.
