Rosie1963
I would like to get the whisker pole (15ft) off the deck and use the Hiscocks technique of using very ong track up the mast and using tackle to store it up ended. I cant afford bronze track, so sadly will need to use aluminium T track - do you think 25mm which seems to be the standard AWB spec - will be enough screwed into a hollow silver spruce mast?
