2006 Squadron 58 Shower Sump Wiring
mikesyam
9 Nov 2005
Good morning all a few months ago a pal removed the shower sump because the fittings where the pipes connect to it had broken off the main sump it ended up up being forgotten about until the other day when we fitted the new one but but there is no 24 volts now on the supply it was working perfect before there is 24 volts coming out of the switch but it disappears into the wiring harness there is is a couple of fuses under the dash and electric panel but they are all ok so I'm wondering if anybody knows if there is is a dedicated fuse anywhere else many thanks Mike
Apologies for the pronunciation I couldn't work out how to do a comma on talk to text
Fuses rather than thermal breakers?!? :oops:
Are you sure that nobody fiddled with the electrical system in the past?
That's something I wouldn't expect such reputable builder to use anywhere onboard!
The shower sump is on the same switch / breaker as the water pump.
There is a grey termination box next to the sump.
Test it again as if no one has touched if it is unlikely to fail. Also cycle the helm breakers - all the 24 v ones. It should be on water pump but yours could be different.
If stuck you should be able to steal 24v from the toilet pumps / black tank pumps which are next to it
