openwater 3100
New Member
Hello,
I am having an issue with my ( I believe to be edc controller ) once I put key in " on Position" and power up the edc panel with green light in N position, Stbd engine starts fine then Port engine will try to crank but just engage started for half a second then lose power to port edc contol panel.
I have to turn port ignition switch back to off position then reset the edc panel but every time I try to start the port engine it cuts power to the port side of the edc panel which tells the engine to stop cranking.
any thoughts?
Thanks in Advance.
any thoughts?
Thanks in Advance.
