Stemar
I need to replace Jissel's lower rudder bearing.
According to the Owner' Club, the right way to do this is to cut off part of the old skeg to free the rudder and the old bearing, then get a plastic through hull of suitable dimensions and mount it in a metal bracket, thoroughly glassed onto the skeg. Weight bearing surfaces are supplied by oversized SS washers and a little ingenuity (SS rudder stock)
Problem 1:
Since most plastic through hulls seem to be nylon, and nylon swells in water, I need to know how much clearance between the rudder stock and the inside of the through hull I need to allow for the swelling. Are we talking 1 or 2 mm, or more on a stock of, from memory, about 40mm?
Problem 2:
I'll have to work outside, during the winter. Keeping the job above 15 degrees for long periods of time would be a problem as I only have limited electrical power. Will epoxy cure, albeit slowly at lower temperatures (5 - 10 degrees), or will it go manky and never reach full strength?
If the latter, is there an additive to help things along?
Problem 1:
Problem 2:
