1gm10 yanmar
gd7hej
11 Jan 2002
isle of man
hi,coming back from whitehaven at the weekend,we lost the wind.so went to start the engine,the engine would not turn...i tried it with starting handle it would turn then stop and was quite difficult to turn the rest of the way,it would turn okay with decompression lever upwards??any ideas??seems something was stopping it.it is running okay,a couple of very stiff turns she started on the key again..please help..regards graham..
gd7hej
11 Jan 2002
isle of man
Hi okay when i turned it normally i had to use both hands and a lot of weight on the handle.this was really abnormal,the starter would not turn it...regards graham
airbubble
19 Aug 2002
Netherlands
Looks like some fluid (water or fuel) had entered. When turned against compression it blocked, when you opened decompression lever you pushed most of it out and were lucky. Question remains why/how did it get in ? Leaking injector is one cause for a bit of fuel, which from your story looks the most likely to me. If it was water, it is normally so much that you have to do more to get it out and running again.
jfkal
17 Aug 2001
Singapore
Sounds like fluids in the combustion chamber. Would take of the head and check the head gasket. Had similar problem. Leak was too small to cause major compression loss but did still suck water in after the engine was stopped.
