greggron
Boat now back in after winter ashore, and motor, (Yanmar 1GM10) reluctant to start but did so eventually. But now it seems to be a pattern that it does not start easily – 4x10 sec on the starting button when cold, but more worrying is that it dies when put into gear even when run for ~5 mins in neutral with some revs higher than tickover. It will run in gear if left for longer (~15 mins) to warm.
I should point out that last season it was running fine, started easily and a few minutes in neutral, she would slip into gear and pick up without a hitch.
Causes I have eliminated:
• Blocked exhaust
o
o
o
What other causes might there be?
What would your next move be?
Anyone recommend an outfit that can service the injector in Gosport/Hardway area?
TIA
• Blocked exhaust
o
have taken elbow off and inspected – a bit sooty inside but no real compromise of the inner diameter. Structure in good nick
o have taken off rubber exhaust pipe to check for delamination – clean and in good condition
o rinsed through wet exhaust box – grubby bits in water but otherwise nothing
o exhaust from box to external – clean as a whistle
o exhaust outlet from engine – some carbon build up but nothing too much
• Blocked air intakeo have taken off rubber exhaust pipe to check for delamination – clean and in good condition
o
New air filter fitted over the winter but phenomenon occurs with no filter fitted
• Blocked injector
o
Put a high dilution of injector cleaner in tank
o Once started, and engine warm went for Italian tune up, full throttle for 15 mins (have now done that x3). Happy to push us along at hull speed with no black smoke. No rev counter so cannot report max revs
o Bled fuel system and changed secondary fuel filter, glass on primary filter shows clear fuel, no water.
Engine is now freeing up after running at high revs under load, but stalling when put into gear remains when engine started from cool.
What have I missed?o Once started, and engine warm went for Italian tune up, full throttle for 15 mins (have now done that x3). Happy to push us along at hull speed with no black smoke. No rev counter so cannot report max revs
TIA
