1gm bleed screw - diameter
Sniper
9 Jul 2001
East Coast
I need to helicoil the primary fuel filter housing which has stripped out. Can anyone confirm the diameter of the bleed screw? I think it may be 5mm but would welcome confirmation before I buy the helicoil set.
TIA
rotrax
17 Dec 2010
South Oxon and Littlehampton.
IIRC-and I'm not sure that I do-its M6. I think the last two I bled had a 10mm hex with a phillips screwdriver slot in the top and a sealing washer.
Hope I'm right-and that it helps you.
Good Luck.
Fr J Hackett
26 Dec 2001
Saou
I am fairly sure it's M6 I had to use a bolt once in extremis having dropped the bleedscrew in the bilge in the middle of Biscay.
eebygum
6 Nov 2002
Manchester
KISS - I Had a similar problem on my Contessa26 1GM after the bleed screw was stripped - I epoxied the bleed screw in with metal glue and just bleed from the fuel pipe which exits on top of the fuel filter. Worked fine after every filter change.
Porthandbuoy
27 Apr 2003
The Gareloch
www.backbearing.com
I fitted a priming bulb between tank and primary CAV filter and sealed the CAV and secondary filter bleed screws. I can easily, and quickly, bleed the entire system through by cracking just the hp pump bleed screw.
