Crushing
New Member
Hay all Iam new to this form I have a 1967 merc 100 9.8hp will start for about one second with choke on I'd I open choke there is fuel in carb. It will at this point start with choke off. Also it will idel for a min or so then die missing every few seconds. Thw water is harly comming out pee hole at idel and is hot if i increase the throttle so will the stream. It has a new water pump I cleaned carb twice new gasket kit new plugs blue spark on both cylinders new fuel I can feel compressiod on both cylinders when pulling engine over reeds looked clean
