Tim Good
I have a large side opening fridge in boat with a 12v Frigoboat keel cooled system. I have a fan in the fridge to keep air circulating. However with two large side opening doors I feel a lot of cold air falls from the fridge and I struggle to keep it below 5c even on max setting. I do try and keep the upper shelves full of water, beer or other things to keep it full and prevent cold air from falling out.
The design of the fridge is such that the lower portion is below the opening of the doors so that cold air would remain in the bottom whilst the upper half parallel to the opening doors. My evaporator plate is as high as possible in the fridge.
I had read somewhere a while ago that I could move the plate lower down in fridge, which would have the effect of keeping the lower section cool below 5c and warmer in the top. The suggestion was that the fridge would be easier to keep cold in the lower section were I'd keep meat andnso forth. Beer water can go in the warmer upper section.
Does anyone think this would work?
