12v expert required!
RutlandMike
2 Sep 2006
www.sam2.us
I've lost my 12v power but the 24v is fine. I've taken the boat apart and can't figure out what's wrong with it. Can anyone recommend a good marine electrician in/around Windsor please? Very frustrating and I've given up.
pappaecho
13 Oct 2004
S. Hampshire
Before you go to the stage, of an external electrician, ask yourself how you get both 24 and 12 volt power.
Do you have, for example, separate 24 and 12 volt batteries.
If not then ask your self how you have got 24 and not 12, and could it be that there is a 12 volt converter from 24 volts?
That could be a very good starting point, and it may just be something as simple as a fuse.
If you can give a little more details as to the battery banks, and charging from the engine, I am sure that the forum will be able to help. If the boat is a particular make and is supplied with 12 and 24 volt as standard, then there may be others who have had the same problem
VicS
13 Jul 2002
What about 24 volts being supplied by two 12 volt batteries in series with the 12 volts being taken from the mid point (in otherwords from just one of them) A connection there come adrift, or faulty isolator switch.
First step has got to be finding out how the 12volts is supplied as PE asks in his first sentence.
ccscott49
7 Sep 2001
That is a very bad way of getting 12 volts, not reccomended by anybody I have ever talked to on the subject. Apparently it does not do the battery bank any good atall, with batteries trying to balance and stuff.
So I doubt it's been done that way, I certainly wouldn't and dont.
VicS
13 Jul 2002
[/ QUOTE ] that may be true but it is the simplest and cheapest way of getting a small amount of 12v power. However a peep at Mike's profile reveals that his boat is an Ocean 42. They were fitted normally with two 240 hp engines so on a boat of that class and size with that much grunt under the floor I should think it has quite separate 12 and 24 volt systems.
PE suggests there may be other forumites with the same boat but there won't be many as only 36 were made.
William_H
28 Jul 2003
West Australia
24 volts is a commonly used voltage on large vehicles. This is primarily because of the power needed to start large diesel engines.
For the same amount of power 24 volts requires 1/4 of the current through wires switches and battery. Power equals voltage multiplied by current.
So if you have a large diesel engine it probably originates from a heavy vehicle where the starter and alternator were made for 24 volts. It would be quite foolish to revert to 12 volt components although possible because of the advantages of 24 volt system.
The 24 volts can be an advantage for even simple circuits like the mast head light. For the same power at 1/4 the current you need lighter wire. Not only that but any voltage drop in the wire represents a smaller percentage of total so matters less.
It is normal to get 12 volts for those devices which require 12 volts from a switching converter. This effectively transforms the voltage down. It means that if you need 10 amps at 12 volts you need feed the converter with 5 amps. (actually a bit more due to losses). This is far better than using a resistor to lose 12 volts power wasted in heat where 10 amps at 12 v0olkts would require 10amps at 24 volts. Likewise if you just tap a battery you will be taking 10 amps from half of the battery which really causes trouble when you try to supply the 10 amps from the 24 volt alternator via the unused battery.
I understand some new cars are going to a 48volt system for the same reasons. Likewise you see power transmission lines across the country at 132000 volts and more for the same reason. Higher voltage equals less current equals less copper required for really high power.
Reference the original poster. I'm sure someone can nominate an electrician who can help you, however as a skipper you really owe it to yourself to understand your system so that you can fix most things yourself. Especially when at sea. So if you do get an electrician make sure you get him to explain the system.
I don't believe you can treat a boat like a car. Just getting an expert when it won't go will cost a lot and leave you vulnerable to both being ripped off and being stranded. Boats are no where near as reliable as cars. good luck olewill
RutlandMike
2 Sep 2006
www.sam2.us
Thanks all - I couldn't agree more. Believe me, getting in someone else for anything is always a last resort and I make damn sure I'm watching what they're doing. In this case I have had to admit defeat due to everything being beautifully secured in trunking. To trace all the cables back manually would be extremely difficult, especially as a lot of stuff would have to be removed (generators etc) to be sure of correct tracking. I'm hoping that a qualified sparky will have voltmeters etc that can trace the 12v supply - I'm just likely to short something out if I go fumbling about with something conductive. Does anyone know anyone who can help??? Please???
andyball
1 Jun 2001
umm, power of 24Watts needs 1Amp on 24V and 2A on 12V , so not 1/4 , but 1/2 of the current. /forums/images/graemlins/blush.gif
It may be a bad way to do it ... tapping of 12 etc. ----- but it's not only some boats that do it ... some trucks do it from their twin battery banks ...
With a mobo that is charging its batterys far more than a Sailboat etc. - then surely it's a lesser problem ... batterys will be in better charge state and regular.
pheran
23 Sep 2002
The glorious South
[/ QUOTE ] Thats not the way it is arranged on my boat. The 24V is used only for the domestics and bowthruster and is derived from 2 x 230Ah batteries in series. The engines, including starting, remain at 12v from two 2 x 180Ah battery banks. Any 12v requirement in between is supplied by a number of 24 - 12 V converters although most of my ancilliary stuff, plotter etc, seems able to work off anything in the 8 -32v range. The engines have both 12v and 24v altenators.
Andrew_Fanner
13 Mar 2002
ked into poverty by children
I have two banks of 2 x 12V coupled in series. The bank attached to the S/H engine have no alternative connection, the P/H set have a central tapping for 12V. My switches have a 0,1,2,Both for 24V which selects both pairs for Both and a 0,1,2,Both for 12V that appears to treat the P/H battery set as two independant 12V sources that still charges at 24V across the series pair. I have yet to work out precisely how this is set up but its a so far best guess. I have also yet to work out what is going on if I have 24V#2 (which is the 12V enabled side) selected as well as the 12V Both.
Any Thames based reader who cares to look and provide a definitive answer will doubtless get beer:)
