12 volt computer monitors
Pseudemys
New Member
17 Jan 2006
www.virtualreinhard.com
Is anybody using a decent sized (15" or more) flat panel computer monitor that genuinely runs on 12v, that they could recommend? It will be used for photo editing at anchor. All the really high definition panels seem to run at 24v / 60W++ which is cutting it a bit fine in terms of liveaboard amperage.
I have an Iiyama Prolite 15" monitor on the boat driven directly from the boats 12V system. It uses around 2A total compared to maybe 4A when I had it powered by a small inverter.
Aha - the 'Great scheme of things' lol /forums/images/graemlins/smile.gif
Well, its, at this moment, sat in La Coruna, surrounded by half a teak forest.. tins of finest varnish.. disolvente universal, paint stripper... power tools.. boxes of parts etc etc..
In the great scheme of electrical usage... well /forums/images/graemlins/wink.gif - thats the case of you fit the power station and charging regime to suit your needs.. saving a couple of amps here n there makes no discernable difference.. if you want the monitor.. turn a couple of lights off, or turn the fridge down 1 degree..
Often you pay more for 12v kit than 240, especially if its a specific resolution monitor you want..
ps, the refit is becoming a 9 to 5 job.. aghhh
Hope the weather still good in La Coruna, Im back in the cold North - Good to meet you and good luck with the refit.
Monitors - I have 24v and Laptop with 19" screen both on a regultor set at 12.3volts of clean power - never had any problems with voltage as this would be apperent quite quickly. Total draw with brightness turned down is well under 2 amps and even 1 depending on the usage.
