lampshuk
When I took Drifter's mast down this winter I took the opportunity to send the M/head wind indicator unit back to NASA for refurb: replacing the direction indicator and fitting a new anemometer cup-set. I was pleased to be able to take this route, rather than replacing the whole m/head unit. Cost < £40, I think, rather than >£100 for a new one. I believe it's about 15 years old.
However, I was disappointed to discover when I got the mast back up again, to find that not only did the w/speed indicator not work, but the direction (which had worked before) was also not working.
To cut a long story short: I called NASA and they gave me enough info about the connections to troubleshoot the problem, which turned out to be the 5-Pin DIN connector connected to the rat-tail off the display. The female connector on the long up-mast cable was a DIY job and though it looked fine from the outside the soldering was poor (dry joints, no heat-shrink or connector lube protection) and 2 joints had failed. I re-soldered it and now have a fully-functioning windicator.
Here's the info: not exactly rocket science (by NASA standards) but I was able to view the wind speed pulses at the mast base connection with my little pocket 'scope so knew the problem lay elsewhere.
Silver = negative supply - all below are reference to this
Red = +5V from display unit
White wire is wind speed data - 1 x 5V 10 millisecond pulse per rev of wind cup
Black = 1 to 4V (approx) depending on angle of wind vane (SIN)
Blue = 1 to 4V (approx) depending on angle of wind vane (COS)
(these two above are 90 degrees out of phase)
NASA MARINE
Boulton Road
Stevenage
Herts
SG1 4QG
www.nasamarine.com
NASA MARINE
Boulton Road
Stevenage
Herts
SG1 4QG
www.nasamarine.com
