Skylark
I'm planning to join 3 x 12v battery negatives wires using a simple busbar. Of the 3 cables, the biggest is 95mm2, the other is 75mm2. My choices of readily available material is either 1/8th x 1 inch copper strip or 4mm x 25 stainless steel strip. I'm also planning to use M10 stainless steel bolts with locking washer to clamp everything together.
Which material would make the better busbar?
