0701 sang mao breaker 20A
simonfraser
13 Mar 2004
Outboards 4 mobo’s, unless you do a lot of miles
these are in my fuse board from 1999, with all the wires soldered on
press to reset, that works, is there any way to switch them off other than shorting them out ?
i need to know what they all do and the lables with them are not sufficient to sort this out
then i can design and order a new fuseboard
Inline fuse with a clip on each end of a length of wire, turn off battery, clip one end on positive terminal, other ond on each circuit breaker output terminal in turn, what ever works is on that circuit.
Photo may be interesting as well for comment.
Brian
Wouldn't the 12v positive feed back through the breaker and power everything else on the common positive feed?
Paul, hm, yes that would work but send a 20A spike through the system and the EDC
not sure if that is the best for the EDC, there are at least 20 i need to 'test'
PVB, yeh that would feed back through the breaker imo
if i had something to gently increase the amps to trip them i would be happier with tripping them
gently increasing the amps may take more than 20A to trip them and thus straining the supply ?
risking my EDC is not good and some of the breakers are on the engine circuit :(
options:
1) cut them, check it, solder it back on, order new panel
or
2) rewire to a new panel and then order suitable strips with the correct lables engraved to fit on top of new panel
For my sins I used to supply the Riviera switch panels to Marine Project in the early part of the 90's, also redesigned most of the Princess panesl, long story.
I think you will find the panel has plugs and socket conectors, one of the things I introduced, unless someone has totally rewired the boat.
Brian
I don't think that answers my question...
Brian
if only, nope it has def been hard wired in :(
You are not sending "spikes" anywhere, all you need to do is to increase the load to something in excess of 20a on the load side of the breakers, they will trip and shut the power down on that circuit. Whatever is on that circuit will be "unaware" of the additional load, when the breaker trips that circuit will just lose power, same as if you turn the batteries off. You won't be "sending" anything to the EDC or to any other circuits downstream of the breaker, you're simply drawing a load through the breaker.
Brian
PVB is correct, connecting the battery to a breaker output will power everything up.
Brian
Not sure how Riviera and Princess relate to the OPs Aquadore ?
Besides, if he unplugged the panel connecting a positive to the breakers load terminal won't work, as the panel will be, erm, disconnected.
  • Like
Reactions: pvb
