Thedigger
I've stripped the pump of the 1G and removed the 2 seals. But trying to fit the water seal in the grove on the pump is impossible. There seems to be too big a gap between the lip on the seal and the back of the impeller. The lip on the pump is only about 2 or 3mm deep getting the seal to stay in place is impossible. I'm wondering if I need to get a new pump. Looking through the hole from the impeller side the housing is very rusty. I banged in the water seal and it only just enters the hole and there is a gap of about 3 or 4mm between the seal and the back of the impeller. According to practical boat owner article on this the seal should meet the back of the impeller. The problem is either I have the wrong size water seal or the grove that fits the seal is so badly corroded there is no room for the lip - anyone help as buying a new pump is expensive - I did notice the invoice for the seal said there was an earlier edition model so perhaps I have the right oil seal but the wrong water one.
