Stono
When coming back to idle after a fast run the oil pressure warning lights, a few revs and it goes out, no more problem, any one come across this before. Yanmar 6BY3 260 hp
Most engine manufacturers oil pressure alarm strategy will be between 0.2-0.6 bar dependent on N/A or turbo, I would get an oil pressure measurement taken from the main oil gallery when the engine is hot at low idle, the figure will tell you your engine condition.If the oil is the correct grade/ level and engine temp. is normal then some suggestions, in no particlar order:-
i) worn crankshaft bearings; ii) worn oil pump; iii) faulty oil pressure relief valve, (assuming there is one); iv) faulty oil pressure switch.
