yanmar GM10 wont start
kieronriley
6 Jan 2004
mersyside
a boat in our club has a a yanmar GM10 and during the winter we had to put some oil down the air intake to start it , but it was easy enough , from the first bit of a problem it sometimes would start without the oil and sometimes it needed it .on launching it needed oil but then ran fine for over an hour. however the owner went out yesterday and i went with him to check it would start ok ,but no chance even putting oil down ,no luck so i put my hand close to the air intake ,Filter removed and turned the engine over only to get the palm of my hand covered in oil again and again . I can turn the engine over by hand just by turning the alternator ,so there dosnt seem to be any compression. the engine had been unused for over a year ,i can only think a sticky valve BUT? anyone had such a fault and can maybe offer some help it would be most appreciated. the owner is a newbie to sailing and i told him that this forum was the best aid to all sailing problems. Thanks for reading this. Kieron
vas
21 Jun 2011
Volos-Athens
a couple of bolts to remove the rocker cover on top, turn engine by hand again and notice what the valves/springs are doing.
then bring on the mechanic...
kieronriley
6 Jan 2004
mersyside
hi , and thanks for your answers, I have already removed the rocker box , the valves are moving apparently ok but don't really know how to check if they are both closing properly , but would i be right in thinking that it would be the intake vale not closing properly .
black mercury
4 Jun 2013
scotland
Make sure the valve clearances are OK. At the moment simply check that there is clearance when the valves are shut.
Turn engine over by hand until valve is fully pushed down, then rotate engine one complete revolution so that valve is completely closed. Look at the gap between the rocker and top of valve stem. You should be able to rock the rocker with your fingers at this point.
penfold
25 Aug 2003
On the Clyde
Other causes include debris in the valve seat, displaced valve seat, broken valve head, etc. When cranked by hand does it spin freely? What position is the decompression lever?
kieronriley
6 Jan 2004
mersyside
hi ,Thanks again for responding. the decompression lever is closed, and yes it spins freely. i will next check the valve clearance as i think that if the inlet valve is far to big then this will maybe point to the fault,but i do think its off with the head (to quote a French revolution cry) and se e what we can find . is there a general agreement on that,thanks .Kieron
RichardS
5 Nov 2009
If one of the valve clearances is too large and it is clear that the valve is not moving up and down to the full extent of its travel, you may well be able to free it off by careful use of a mallet and an old screwdriver to move move the valve up and down a little with WD40 sprayed around the stem seal. Depending on the head design. you might be able to easily remove the rocker arm and tappets and then you should have clear access.
You will know once its free and this will save disturbing the head gasket.
Richard
earlybird
18 Aug 2004
Cumbria; U.K.
Are you sure that the excessive valve clearance is on the inlet, rather than the exhaust? A possibility is corrosion of the valve stem below the guide which prevents proper closure. This could be caused by sea-water entering the exhaust passage due to a failed elbow. The GM engines suffer from that fault.
kieronriley
6 Jan 2004
mersyside
Thanks very much for your helpful replies , I have read about the exhaust valve and can see how this would cause a problem but would that create the symptom of blowing oil out of the air intake ,I’m unsure as I thought the only valve giving access to the air intake would be the inlet valve. Am I not correct in that thinking, I really do love to learn so please tell me if I’m wrong, thanks. Kieron
black mercury
4 Jun 2013
scotland
Yes, unless the exhaust is blocked, which I don't think is the case with your engine.
It is possible that when squirting oil in through the inlet valve the oil has maybe mixed with dirt in the cylinder head on its way into the cylinder and this dirt is now stuck across the valve face preventing it from seating. Before removing cylinder head I would use some brake cleaner or similar and spray it down the inlet, getting it close to the valve as possible. Turn engine over so that the inlet valve is open so the spray can clean the whole valve.
179580
19 Jun 2020
In the primary post you mention you had to introduce oil into the engine to start. This an old trick to increase compression due to worn bores. stuck rings. Although you seem to have some valve problems now, I would diagnose a lot more than is obvious.
As a minimum, remove the head and get a valve and seat job, This would also give you access to the top of the piston to assess possible further problems.
JumbleDuck
8 Aug 2013
SW Scotland
My guess is that the exhaust port in the exhaust port in the head has rusted through. Sorry. Get your credit card ready and brace yourself for the lubricated fist of Yanmar's spare parts pricing policy.
Caraway
11 Aug 2019
England
Expose the rockers. Hold the rocker in contact with the valve stem and give it biff with a hammer. If the valve is stuck it could release. You will notice if it does. Make sure the rocker sits back in the socket in the pushrod top when you have done.
You may have loosened the valve, or not, but unless you are very hamfisted you aren't going to break anything. You often have to tap valve caps to release the collets when dismantling engines.
It'll take no time and if it hasn't any effect you are going to be removing all that gear anyway. You just have to keep dismantling until you get to something that is wrong. Inspect everything as you remove it.
It's hardly a tricky job.
Lack of compression can also be the result of a bent conrod. This usually follows from water getting into the cylinder, which in turn can come from a failed exhaust elbow. The official Yanmar workshop manual describes how to test compression via piston to head clearance.
However, if valves are not stuck, head off is the way to go and hope that you don't see post #13!
  • Like
Reactions: B58
179580
19 Jun 2020
If the valve is stuck that may very well free it. BUT, it may also shift the stem guide, and, as the original post implies, the engine has been rotated with the start motor a bent pushrod may be on the cards
Caraway
11 Aug 2019
England
Then his problems are just beginning. I always try the least invasive and most likely solution first. It it is just a stuck valve, it may free. If not ... onward Horation.
I just, in search of a light clacking noise in my MG engine, ended up replacing a piston and conrod. Not absolutely essential, but once you know it's there.... I enjoyed the work.
RichardS
5 Nov 2009
Post #8 seems relevant. ;)
Richard
