gilesfordcrush
I am suffering from an intermittent starting problem on my Yanmar 3GM (Moody 30). Pushing the starter button will fail to turn the engine over about 75% of the time. The other 25% of the time the engine will turn over and fire instantly. I am pretty certain this is not a battery problem, but is most likely a well known issue of insufficient current getting to the starter motor solenoid. My main reason for ruling out the batteries is that on every occasion that the engine has failed to start, I have managed to get it starting shortly afterwards, with no additional power, and it turns over quickly and fires immediately.
There are many stories on internet forums about this issue. It would appear that the accepted fix for this involved two approaches. The first is to simply ensure that all electrical connections are good, clean, and making solid electrical connections. The second is to add a simple automotive 30A (or thereabouts) relay that takes high current from the starter motor wiring directly onto the solenoid, switched using the existing bush button circuit.
The symptoms I have are that once the key is turned (and the alarm sounds) and on pushing the starter button there is an audible click, the alarm stops (presumably as all the current is being drained) and the engine does not start. If the button is released the alarm may start again, or once the key is turned to off and on again the alarm will start, and another start attempt can be made - with a chance of success.
I'd be very interested to hear from anyone who has experienced this kind of problem, and what approach they took to resolve it.
Thanks, Giles
Thanks, Giles
