dunedin
So what do peeps make of this announcement by RORC and RYA ? RYA joins forces with RORC Rating Office and SW Yacht Time Correction Factor
As mrming says, NHC hasnt been popular. Most sailors dont understand the maths behind it and the concept of handicaps changing during a series is not popular - PY was supposed to be like that but it rarely happened. The gap has been filled by Byron who does a sterling job but again not universally accepted. Pity because NHC was developed based on RORC systems and with the objective of encouraging racers to move to IRC but casual racers dont want to cough up £70 when they can still use the old PY or Byron.
We do need a performance based system IMO. I have seen 2 Sigma 33s racing in a series, one with experienced crew, good sails, stripped out etc and the other with a few pals, old sails, lots of junk on board. All they could afford. On different performance based handicaps both boats were encouraged to improve. On bare handicaps one would simply have stopped casua;l racing.
The popular PY was of course a performance based system. Race committtees were supposed to alter base numbers in line with performance with the obvious complaints of bias fiddling etc. NHC made the adjustment automatic
Having said all the above, is the new system really aimed at replacing NHC or is it simply a base IRC without the £70. The handicap calculation looks very much like the one used for NHC ( which was done by RORC) so could the same result be achieved by simply using NHC base numbers without change race to race?
You are making two assumptions that are IMO wrong. Firstly you are assuming that there is only one choice when there isnt. The keen serious racer can use IRC whilst the occasional family racer in his old bilge keeler can go NHC ( or PY as was). The second is the hard yards comment - is having a lot of money and spending it on all the latest kit plus even hiring hot shot crew really the "hard yards" ? IMO its simply buying to silver ware which in those circumstances is really worthless. You see this approach most obviously in the likes of the Smericas cup or the Sidney Hobart but it does exist at club level in the richer areas like the Solent.This is the logic with which I disagree to an extent.
Certainly it's fair to assume that the boat taking it seriously will win a statistically significant proportion of the races. However, is this a bad thing?
If it leads to fewer boats on the water, then yes. However, that's only the case if the mates with a tired boat will stop racing simply because they're not winning, and I'm not convinced that's the case: if it's an excuse to go out with mates after work and have a bit of fun, then the result doesn't really matter, no?
Second, and this is a bit more of a philosophical point about competition, is it right that a boat that's not prepped for racing, full of weight and with baggy sails beats a boat with experienced crew, new rags etc regularly?
Under a performance based system, spending money on new sails is penalised, as is going out outside of racing to practice, or spending an evening with the textbooks, or learning the tides, or...
I get the desire to reward progress, but I'm not convinced that it should be at the expense of those that do the hard yards.
For example, in most fleets those at the front are only to happy to share their tuning numbers, strategies, boat bimbling tips and the like. To me, that's a more useful way of building a fleet.
It's easier if you have some YTC certs with the submitted measurements to check against.No that the equation is available, I have two questions that I can't work out:
- There's an equation to measure Spinnaker Area Allowance, but it's not used in either the fin keel or bilge keel equations nor the white sail equation nor is it mentioned anywhere in the text. Any idea what it's for?
- There's a random value assigned for keel flare (kg ranges from 1 for a slight flare or bulb to 5 for a winged keel), but there's no calculation method nor guidance. I had a look at some of the values from Dartmouth last year and this value seems a bit arbitrary, even between boats in the same class.
One of the objectives of NHC and its associated calculations was that any handicap adjustment would be out of the hands of the race officer / committee etc since this was one of the most contentious areas.guess I won’t be prioritising racing this year. The roller caster that has been my swytc handicap has reared its ugly head Again.
After a few years of sanity and good fun close racing the powers that be have decided to cut my handicap by thirteen points. Since having our current boat our handicap has been anywhere between 847 and 913 depending on who’s turn it is to do the back of a cigarette packet calculation. None of those figures bear much resemblance to the actual formula .
onwards and upwards
That’s if theres a sales brochure. If you sail somewhere where everyone has new boats, maybe.YTC isn't measured, it's taken from the sales brochure.
You can completely strip the boat out of all woodwork, change the sail size, etc. doesn't affect your rating.
True, you can. It would be called cheating but I m sure that some people do that and think its clever / crafty.YTC isn't measured, it's taken from the sales brochure.
They have 6 contessa 32s and they all have (marginally) different ratings.YTC isn't measured, it's taken from the sales brochure.
