simonfraser
wallas do a 1300 is that man enough for a south UK winter ?
Take a look at the Chinese copies on eBay. Here is an example.wallas do a 1300 is that man enough for a south UK winter ?
174151325580
Put that item number into the eBay search bar. I have a 5kw version on my 8.6m boat and it's great. Just swap the fuel lines and get a proper SS exhaust. For this money you can't go wrong. Even if it only lasts 3-4 seasons you just buy another and swap them over !!
Well neither has my Chinese one. Apart from the exhaust they supply which is for a van not a boat the quality is as good as a webasto or eberschpacer.fair point, but i don't want it failing during a journey out, my previous 'proper' heater has been no problem and has not set the boat on fire
For under way I would connect a car heater to your inboard. No running costs and extremely reliable
I fitted a Mikuni 2kw to our 805 and found it adequate with just 1 outlet in the fore cabin and a demister . Didnt boat in the depth of winter tho
...the universal heater demisters look intersting, but will be at anchor for some time, so that would not be suitable
Providing you set the heater up you should be good - if its any consolation I have gone with a Chinese one with a aluminium body.fair point, but i don't want it failing during a journey out, my previous 'proper' heater has been no problem and has not set the boat on fire
Just to add on my install I used butterfly outlets so you can close off what you don't need. Decent stainless not the plastic ones.
