• REMINDER
Vp2002 fuel lift pump
stu9000
8 Mar 2008
near kingston upon thames, surrey
Hi my 1988 westerly engine is smelling a bit. I'm sure it has got worse and it looks like the lift pump might be weeping where the manual pump lever goes in. Is this common? I assume I will need to replace the whole unit?
Home: Kent. Boat: Chichester
Any diesel leak from below the diaphragm indicates a failed diaphragm and means that diesel will also be getting into your engine oil sump, but check it is not simply one of the unions or the cover joint which is leaking
very few parts are available for the old type pumps ... Check Keypart's price for replacement pumps
2002 - Diesel Engine
You may also need a new O ring seal between the pump and the crankcase
stu9000
8 Mar 2008
Thanks Vic
stu9000
8 Mar 2008
Lift pump (sealed)
£85
Keypart
Ill give em a ring but I suspect Im replacing a non sealed pump with a sealed unit and thefore would need to buy this fuel pipe as well
£99
Keypart
Seems a huge amount to pay.
Has anyone fitted a modern pump.
Any thoughts on reliability and fitting pipework?
Possible Pumps
12V Petrol Diesel Gas Fuel Pump Universal Inline Electric Pump MarkUK® HEP-02A: Amazon.co.uk: Car & Motorbike
or
Easticks28
12 Aug 2009
Norfolk Broads
Lift pump (sealed)
£85
Keypart
£99
Keypart
I bit the bullet and went for that option some time ago. Not only was the diesel pong eliminated but so were the starting difficulties.
I thought the pipe was abit of a p*ss take, and wondered afterwards if I couldn't have had one made up somewhere.
I tried the route suggested by Pandos.
Went to a well respected local distributor of all things diesel and despite a long search of his very large stock and on line as well he was unable to help. It was the mounting flange that was the problem.
scottie
14 Nov 2001
scotland
From memory 12yrs plus I believe the pipe may be usable if not a hose supplier may make one up at well under that price
stu9000
8 Mar 2008
I rang Keypart and they were their usual helpful selves.
The repair kit is no longer available.
The unsealed original unit is no longer available.
So I need the sealed pump which means i need the pipe as well.
Perhaps there are various workarounds. There must be fabricators out there who could make a pipe for less.
Probably this could be done in combination with a tractor lift pump.
But the chances of the fittings not fitting seem high.
Also, there is the time waiting for the parts, all the while relying on a fuel pump that is potentially disintegrating daily.
I'm going on board this afternoon to double-check but unless someone has walked this path and can offer a solution I am likely just to spend the money and be done with it.
scottie
14 Nov 2001
scotland
The replacement pipe uses the same banjo bolts and washers so having a flexible pipe made up would seem viable and I still have a thought the original pipe might be ok with some tweaking if desperate
kacecar
29 Oct 2007
UK
If you decide to go for a sealed unit I don't think the piping need be a problem. I too had to change a faulty pump of the older unsealed type for a new sealed one - had to, I was stuck miles from anywhere and time was tight. Naturally the pipe routing had to change so I merely cut the ends off the standard hard pipes, leaving a suitable length of the hard pipe on each end fitting, and then I joined them up again with rubber fuel hose and good quality jubilee clips. This flexible "quick fix" has now been on there for 15 years.
stu9000
8 Mar 2008
Good solution. Certainly good enough for me.
stu9000
8 Mar 2008
I had a look yesterday. It's definitely weeping. I'm not exactly sure where from. Possibly the pump lever. I'll call parts4engines today. Will probably buy the unsealed unit as it looks like a direct swop.
PabloPicasso
12 Feb 2010
I did rebuild my vp 2001 pump as it weeped the same as yours. I think VP did a kit so no need to replace with the sealed type.
